Prop question?
Bubbco
Prop question?
I have just restored a 24' pontoon boat and powered it with a 115 Johnson off a 17' Trihull.The prop on the motor was 17 probably too much prop for such a boat. Does anyone know the average prop size for this type off boat and motor combination?
MGuckin
Re: Prop question?
Re: Prop question?
Not sure of this type of hull but why don't you try it. If you have a tach, rpm should be from 4500-5500, I believe @ WOT. Sounds like a good starting size. I think you may have to go a few inches smaller in pitch. 1" of pitch = 200 rpms. Lower pitch will increase rpm. You don't want to lug the motor nor over-rev.
Dhadley
Re: Prop question?
Re: Prop question?
Absolutly try it and check out the RPM's. It may be a tad stiff. You may end up with a 15 but try what you have. Shoot for 5600 to 5800 RPM with an average load.<br /><br />Good luck!
Ross J
Re: Prop question?
Re: Prop question?
The book specifics for 115hp Johnson say...<br /><br />Prop supplied with motor - 3 blade, 13" dia, x 19" pitch<br /><br />Ross
