ratdude747
Thread starter- Joined
- Sep 30, 2023
- 487
Reposting something from my ongoing build thread that probably should be a post in this subforum. The boat is a 16' Starcraft Montego with a Mercruiser 888 (302).
I've edited the wording a bit for clarity.
Supposedly they were hitting 60mph in this thing before it was out of service; it had been (badly) upgraded to a 4 barrel carb. It still has a 4 barrel in my setup, but I've swapped the carb out to a marine rated unit (among other upgrades, fixes, and redos). They liked the plastic prop for the flexibility helping with hole shots (and getting on-plane faster). I saw no fewer than three sheared prop cores in the garage/barn I pulled it from.
Am I correct that the aluminum prop is junk? My current plan is to stick with the plastic unit, but I'd like a second opinion before I spend any money on it.
Different subject while it's on my mind: props.
The outdrive currently has a 4-blade composite on it. Here's the remains of the box: (edit: this is to provide the specs on the current prop)
Also included was an aluminum prop. Has a ding in it:
The damping rubber is cracked too... Probably junk? FWIW it's part number 48-74888-21, also marked with other things:
Might be original; the PO was very fond of the plastic props (based on how many bladeless (crashed) cores were in the garage).
Thoughts?
