NewBoater25
- Joined
- Jun 23, 2009
- 6
I have a 1967 80 HP Johnson outboard motor, model number 80753 M, serial number E02761. I took the boat out after rebuilding the carbs for a test run and once I got out and put the boat in gear it would not go anywhere. When you tried to give it any throttle it would rev up but not move either in forward or reverse. Brought it in to find prop cone was broken drive pin sheered and missing a thrust washer. Went to marina replaced all those parts and took it out again to have it do the same thing. Came back in and the drive pin was sheered. I am new to boating and was wondering what you experienced guys thoughts were. Any help would be greatly appreciated before I dump all kinds of money into something that is ultimately junk.
