justfishin711
- Joined
- Jul 21, 2007
- 6
I am looking to switch from an aluminum to a stainless steel prop for better all around performance and top speed. I am unsure of what specs of new prop should be. thanks for the help.
Iboats Boat and Motor Info
1. Year, make and model of boat 2003 palm beach 23 white cap center console
2. Length, width and base weight of boat, look for boat decal on back of boat 23 ft 2800 without engune 8'6 beam
2a.What is the maximum recommended HP for your boat 250hp
3. Number of people and gallons of gas normally on boat 3 80 gallons
4. What do you use the boat for - bay fishing, crusing in bay
5. Is it a Deep Vee and if so how many degrees of Deadrise - modified vee - (based on sea craft)
6. Year, manufacturer and model of motor 2003 yamaha ox66
7. HP and gear ratio of outdrive IMPORTANT 200hp 1.81
8. Manufacturer?s recommended Wide Open Throttle (WOT) range 4500-5500
9. Anti-ventilation Plate height above the bottom of the transom of boat if it is an outboard in inches, use a straight edge or a board under the keel and sticking out to the anti ventilation plate for a reference, and take about 4 pictures for us to see.
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin, whale tail or trim tabs - trim tabs
12. Manufacturer, model, diameter, pitch, number of blades and whether SS or aluminum props.
michigan wheel 992004 Vortex? 3-Blade Aluminum Propeller Housing, 14-1/2 dia x 19 pitch
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for less than $ 50
RPM ___________ Speed (GPS)___________ No. of people ____________ Gal. Gas ________
14. Are you at sea level or a higher elevation, give us the elevation in feet _sea level_____
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way by only using the control on the console, checked compression, looked at the plugs and checked spark, is the bottom of the boat clean and barnacle free, and have you checked the Tachometer against a mechanics tach, all of the foregoing could be the reason your prop is not attaining full RPM. yes
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop. 1 year old prop, no, not sure looking for better performance
17. Does the prop show any damage that you can see - yes chip, banged up
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations - better performance, better high end
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
1. 3000 RPM 16
2. 3500 RPM 21
3. 4000 RPM 26
4. 4500 RPM 30
5. 5000 RPM 33
top rpm is 5200
thanks
1. 3000 RPM 16
2. 3500 RPM 21
3. 4000 RPM 26
4. 4500 RPM 30
5. 5000 RPM 33
top rpm is 5200
thanks
