prop removal 72 sears
wizzy214
just trying to figure out how to take off the propeller, removed the cotter pin tapped with hammer doesnt budge. is there something im missing???? or need to do..
thanks
1972 ted williams 7.5
LKaras1
Re: prop removal 72 sears
You need to remove the shear pin also. look for a tiny hole and tap the little pin out. You will have to look real close for it.
wizzy214
where is this little pin???
thanks
You have to un screw that nut on the end and it should fall off if not the pin they are talking about will be under that nut.
EKavanagh
Where was the pin? I just acquired a 70 Sears 7HP and have the cotter pin out, nut off, and can't get the prop off.
Help!!!
Ed
