Prop Rotation
Larry E
On an OMC stinger outdrive does the prop turn clockwise or counter clockwise in forward?
Larry E
Redrig
Master Chief Petty Officer
Re: Prop Rotation
Larry E
Fairly certain that on my electric shift for Forward it rotates clockwise if you are looking at the boat from the rear.
not sure on a 400 or 800 though.
Don S
Re: Prop Rotation
Remove the coil wire from the coil and ground it, turn the ignition switch to run (if electric shift), shift into forward gear, then jumper the starter while in gear and see which way the prop shaft turns.
