Can any one help. I have been working on an old glastron v143 jetflite with a 50 HP Merc 500 & a mercontrol unit.
I finished working on the boat and turmed my attention to the mercontol unit and replaced the inginition switch and the choke switch and then re assembled the unit.
then on the engine i replaced the starter motor and the solenoid.
It started ok and the mercotrol seemed to work ok (if very stiff) and the propeller turmed fast when you pushed it forward in gear but there was less play when you pushed it the lever backward but at least the propeller changed direction.
All seemed well but when i put it in the water and pushed the control forward the prop turned anti clockwise and the boat moved backwards at speed. When you pulled the control backwards then the boat moved very slowly forwards>
the guy that had the engine before me was a not a good mechanic but i think he did have the bottom unit off the replace the impeller.
Could he have connected something wrong when he reassembled or is if me messing with the mercontrol?
or is it something quite common related to something different?
any help at this point would be good. I have the mercontol in two pieces and have just removed th lower leg to see if i can fix this issue once and for all.
Help please!
Regards
Sailorden
