prop selection for 75hp merc on spectrum dominator 17 aluminum bass boat
raiderenvy27
hey everyone i just bought a used outboard 2 cycle a 75hp mercury that will be on my 17ft spectrum dominator bass boat, which is the same thing as the bass tracker bass boat... does anyone have this setup?i if so can someone recommend a prop for it, as in size and pitch?
dustin
steelespike
Re: prop selection for 75hp merc on spectrum dominator 17 aluminum bass boat
Unfortunately finding someone with the exact setup and activities is unlikely.
If it has a prop you should do a test run and get the prop size,wot rpm and speed.A gps for speed is best.
Be sure the motor is mounted with the antivent plate(just above prop) about even with the bottom of the transom.
Let us know your results and we'll get you started.
