Prop selection II
JoeCrow
I just bought a 2002 Merc, 125hp, 2 cycle motor for my 1986 Bayliner 19' cuddy
The new motor doesn't come with a prop
The boat ran fine with the old motor using a 12"x17p prop
Using Merc's prop selector, they suggest a 13"x23p prop for my boat and usage, fish and ski
Does this sound right?
Would the engine change cause a need to change from a 17p to 23p prop?
I'm just trying to figure out what prop to buy for the new motor
Re: Prop selection II
Ayuh,.... What was the Old Motor,..??
Did you account for the lowerunit gear ratios,..??
codertimt
So, are you choosing "Fish and Ski" as the boat type when using the Merc prop selection tool? You need to choose "Runabout - Cuddy"...
When I ran the numbers, it guessed a 21" for overall performance and 19" for better accerlation.
I'm guessing you're probably coming from a mid 80's 125 Force? If that's the case, it would have had a 1.73:1 ratio versus the mercs 2.07:1. So you should definitely expect to be moving up in prop pitch. Whether the 19" or 21" would be better suited would only be a guess on our part...unless you happen to find someone with a similar setup. The closest thing I have for comparison is my Dad has a '98 115 Merc on a 17' Ranger Fish and Ski. It turns a 22" prop at 5200rpm. Given you are in a much larger boat, I would personally start with a 19" and go from there...but that's just a guess on my part...
I would really see if you could find a shop/store locally that would allow you to demo something to get a baseline...
Good luck.
JoeCrow
Thanks guys,
Your guess was dead on
it was powered by a 1986 Force 125
Great running motor, but it was a 20" shaft and I have a 25" transom
It gave me fits till thanks to everyone here that helped, we figured it out
So I went to a 2002 Merc 125
Thanks again
