Moody Blue
Thread starter- Joined
- May 24, 2004
- 3,136
1992 Mariner 40HP Magnum currently has 10 1/8" dia 3 blade prop. Unsure of pitch as there is no marking anywhere on it. It does have cupped blades. Am trying to buy a spare/replacement prop but am confused by the listings here on iboats. If I enter the parameters in the selection windows I end up with 13" dia props as the choices. If I enter 25hp in the selection windows I end up with the 10" dia props. What do I do ??? Does the motor have the wrong prop on it ? Have recently bought a tach to install this spring so I have no idea what the motor was running at with the existing prop. The motor is on a 14ft f/g whaler style boat that weighs about 550Ib's including motor if that has any bearing on the selection. Are there other sources of reference to determine the correct prop ? I should mention that there seems to be room to fit a larger prop (13" ?).
