pwiseman
- Joined
- May 4, 2005
- 207
Just bought a new boat. Lund Rebel 1450 with a 30 HP Honda. I did get the Power Trim with this.<br />Boat is 14' 11" and hull weight is 600 lbs with a 75" beam. My best guess on weight including the motor is 1400 - 2 people with some gear, gas and a battery. Max the boat is rated for is 1100 lbs capacity or 1700 lbs. Hull is a deep v with staking hull.<br /><br />The Honda comes with a 9.25 x 12 pitch three blade aluminum prop. My gut feel is that this may be a bit too much pitch. I am looking at eeking out everything I can by going with 3 blade stainless or a 4 blade aluminum. The ones I looked at were 10 x 11 I don't know how much difference the stake will have on performance, but I suspect it will help some getting on plane and giving a good clean water supply to the prop.<br /><br />Reasons for a 4 blade might be getting on plane better when loaded up and I often end up in windy choppy conditions. I value cruising stability more than top end speed, so this might be a good choice.<br /><br />The other question I have is positioning the motor. Transom is a standard 20" and the Honda has 21.7" listed as the height. It won't be easy to adjust once it is mounted. Wondering if I should match up the cavitation plate with the hull or let it sit down under the water an inch or so. Owners Manual said up to 2" under the water is ok. Thinking the trim might compensate if neccesary. <br /><br />The only reference I have is my old boat. 16'8" Lund with 80" beam, and 950 lb hull without the strakes. I ran this with a 2002 Merc 50 EFI and a 12 pitch. This was a decent setup, could have gone up to 13 but the 12 was giving me as much speed as I needed (33 mph on GPS). My calculations ended up with .15 slip as I was getting 85% of the Thoeretical Max (RPM * pitch)/(1056 * Gear Ratio. New boat should be similar or slightly better.<br /><br />Looking for advice. Thanks in advance.
