Prop selection
eutecticpt
Any recommendations would be very much appreciated
1) Performance issue you are trying to correct.
Need quicker acceleration for watersports (wakeboarding and skiing)
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
Mercury Aluminium 48-832834-C1-23
3) Current prop diameter and pitch (required).
14 inch 23 pitch
4) Wide open throttle RPM and speed with an average load (very helpful)
48 mph @ 5000 rpm
5) Engine/drive make, model, year, and HP
1998 GM 4.3 V6 190 HP
6) Boat make model, year, length and weight
2000 Ebbtide 188 Campione, 2600 lbs empty
junior1113
Re: Prop selection
four blade props work best for watersports i would put a 20" pitch 4 blade ss should put you in the 4800 4900 range great hole shots and slower planing speeds
mrmushroomman
Re: Prop selection
I pretty much have the same sit up as you do in my sea ray. I have the same prop also. I had a problem over reving my rpm's which sounds like what you are doing if your at 5000rpm at wot. That is a little high. Should be 4800rpm. Check the back of your tach and make sure the needle on back of tach is in the right spot. Mine was off a tad bit and when i adjusted it i know get 4800rpm instead of 5000rpm with the 23 pitch prop.
