Working on rebuilding a true inboard. I have read the prop shaft alignment guide from Borg Warner and they are very specific and the tolerances are .003 of parallel between the output shaft and the prop shaft couplers.
To align, the engine has to be moved at all 4 corners.
The motor mounts allow up and down adjustment via a sandwiched nut arrangement . . . but the motor mounts also use a locking shim to keep the lower nut from turning once it is set.
Am I correct in assuming I need to bend these flat to set the alignment and once I am done bend them back to lock the lower nuts in place?
The specs call for the final adjustment to be done with the boat in the water. To turn the nuts I need to lift weight off of the engine and I don't see how to do that with the boat in the water.
Are these specs overly rigid? I don't imagine boat manufacturers put every boat in the water for final adjustment, but if I need to, I will.
If you have reinstalled an inboard set up I'd like to know how you did it and your thoughts on the process.
Thanks
Thanks
