bwkre
Thread starter- Joined
- Jul 11, 2010
- 187
1976 Evinrude 25 hp, 25652E.
I have no history on this motor and have only run it in a drum of water once. I was doing a gearbox pressure test and had the prop removed. I noticed shifting from neutral to reverse that the prop shaft moved in. I was able to measure .030" movement.
When shifting to fwd, the shaft moves in then back out and is springy if you push on the end of it while in fwd
In neutral you can push the shaft in and it springs back out.
.030 seems like a lot of movement, would it be a concern or not?
