Prop shaft lenght
bear_69cuda
Hi,
Can anyone tell me the length of the prop shaft for a 1999 3.0 L gen II Alpha one? I'm filling out data on Michagan Wheel prop finder, and cannot find this data in my shop manual? OEM part no is: 44-850308
Thanks in adavance!
Re: Prop shaft lenght
Ayuh,....
You shouldn't need it....
It's the Same Length as the propshafts on the Large gearcase Mercruy Outboards,+ All of the Mercruiser Outdrives,.. Aka. the pre-alpha, alpha, alpha,gen2,+ the Bravo Is....
bear_69cuda
I wouldn't think so, but their prop-finder has it as a required field, and will not proceed w/o the info...
Ayuh,....
You'll probably get Better Answers up in the Prop Forum, than you will from wherever you are Anyways....
The Required Info up there is,...
The Prop there now,..
The RPMs at WOT....
And,...
What it's doing, that you want to do Differently.......;)
