mercs4mark
Thread starter- Joined
- Dec 19, 2010
- 141
anyone know what part numbers will cross with 44-850308 prop shaft alpha gen II
glm 11155 is for an alpha I also, is it the same shaft as an alpha I gen I?
i havent pulled the genII apart yet
Forward compatibility does not always confer backward compatibility. The new shaft fitting into old boxes doesn't necessarily mean that the old shaft will fit in the new boxes.
My history with Merc parts from when I was a dealer is that if they have a part from a previous model or even engine and it is the same as the part in the new model, they will use the same part number. I do know that Ford have in the past use different part numbers for the same part in order to charge more for the same part, if it fits a 'luxury' vehicle for example...
I have done a search by part number (please don't ask how, I could tell you, but then I would have to kill you) and that shaft is used in the Alpha One, Gen II, and a heap of different outboards, but it is NOT listed as used in the earlier Alphas. I would postulate that if it did fit the earlier Alphas, Merc would have listed it as such. The earlier Alpha propshafts do supersede, but not to that number. I would be very cautious fitting an earlier shaft into a Gen II housing.
JMHO
Chris..............
Thx Chris can you give me the numbers that do match that would give me more options
