Hi guys,
Just after replacing all lower unit seals (1990 90hp) after having leakage around bearing carrier.
Running a pressure test i can see the new prop shaft seal is now leaking around its outside surface, ie not around the prop shaft itself but around the seals to carrier surface.
Just wondering could it be that the seal needs pressed in more. Seals are currently inside a few mm's but havnt been pushed against bearing, or is it more likely carrier surface has been damaged, are there any fixes for this?
Didnt want to have to pull seals again
Thanks
Thanks
