Cricket Too
- Joined
- May 14, 2003
- 1,732
Looking for a new prop for the above engine, swinging a 14X17 right now, in decent shape, some very minor dings and scrapes on it and getting 5200 RPM at WOT with normal load. Looking to drop down to a 13.75 X 15 to bring it up to around 56 or 5700.
I have been shopping around and have seen that on some later model V4's, OMC started using the 15 spline V6 lower unit. My boat is in the water and I can't pull the prop to count splines all that easily, so I was wondering if anybody knew if my '97 had the 13 spline shaft or the 15.
If I had to guess I'd say it has the 13, just by looking at it and the fact that it's got a 14" diameter prop on it now, I would assume the bigger gear case would have like a 15" diameter on it.
Don't have the model # on me now but can post it back later if it's needed.
Was just about to order a prop, when I figured I'd check that first.
Thanks, Mike.
Thanks, Mike.
