Prop shaft tolerance
crestapre
Would anyone have an idea of the straightness tolerance spec on a Volvo SX prop shaft?
My port is within 3 thou and the the sp is within 6 thou
I ask because I hit something the other day. The skeg has a tweek at the tip and the edges of the prop fins have burrs.
When I look athe the props in gear they appear to wobble. When in gear w/o props the shafts look to run true. I may have to get the props re-hubbed?
lilmandavis
Re: Prop shaft tolerance
i dont know about 6 thou but 3 is probably on the border but ok. have your props checked out by a prop shop.
