My boat has always had this bow-high riding attitude. So much so that it is often porpoising unless the tabs are down. Other boaters are saying why don't you trim down your outdrive, but it is as down as it can be. So when doing maintenance I adjusted the trailer so that engine is level on longitudinal axis (crankshaft is level). And then found out that even when fully trimmed down the cavitation plate still points upward, not much, but still. So I'm wondering, 4.3 gxi +DPS when trim is "zero" should the axles be parrallel? When trimmed down to -6 shoul the angle be negative i.e cavitation plate pointing downwards?
