prop shaft
krovar
how do you get the prop shaft out, i have remover the outer nut and keeper ut cant get the shaft housing to move, any ideas ar tricks
Texasmark
Re: prop shaft
Well, what are you trying to pull it out of????????
Texasmark
Re: prop shaft
Okaye, if my memory serves me, there are two screws holding the bearing retainer in place, one on top and one on the bottom......immediately in front of the prop. Pulling them allows you to pull the bearing retainer, shifter shuttle, reverse gear, prop rear bearing, seal, and prop shaft. The F gear remains in the housing due to the drive gear mounted to the drive shaft.
I don't think Merc used the old style locking system with it's V engines, but if it did, pull the prop, look on the inner surface of the lower unit housing and you will note it is threaded. Looking further into the lower unit you will see a spanner nut that is threaded into these threads...has 4 tangs on it for removal/installation. Removing that nut allows the same parts to be removed.....Usually the threads are corroded and the nut is almost the diameter of the gearbox so removing this one is a real chore if it hasn't been recently removed, which it usually hasn't and salt water corrodes the housing and makes it near impossible to remove.
Mark
krovar
Re: prop shaft
i have the spanner nut out but i cant get the bearing retainer out
Texasmark
Re: prop shaft
Get a bearing puller....shaft with a sliding weight on it...or make yourself one....slam it till it comes out....clean off any corrosion you can get to on the inner housing.....spray well with a quality penetrating oil.
Mark
Faztbullet
Re: prop shaft
Remove the spanner nut and use a slide hammer or long arm puller to pull carrier. Do not pull or yank the prop shaft as it held in place by the shift shaft and the cam and follower attached to prop shaft. Once carrier is removed ,remove the front shift shaft bushing and shift into neutral. Remove the shift shaft and then remove the propshaft. All the V-6's use the spanner nut to hold carrier in place..
