So I am trying to figure out what prop to get for my 1997 60hp Merc 2-stroke. It is on a 15' VIP Seasquirt CC.
Here's the story...
Bought the boat.
Didn't change anything and on the water it ran WOT at exactly 5500 rpm and 31 mph (gps).
Thanks to tubing and weeds I spun the prop it came with. It was a Michigan 10 1/2 x 13. But something makes me think it was already spun a little bit prior to this.
I bought a Quicksilver 10 3/8 x 13 prop and on the water WOT is only 5000 rpm. Unfortunatly I did not have the gps with me to get the mph.
Does anyone think the same as I do? That the original prop's hub was slipping a bit getting me 5500 rpm and I should drop the pitch to 11? Or that there is such a difference between the 2 manufaturers and that is whats causing the rpm drop?
I use aluminum props if that helps!
Here's the story...
Bought the boat.
