Prop size for 1997 Johnson 115 SPL
egscharf
Currently running a 13.25 x 19 on a 1997 johnson 115spl pushing a seaswirl striper 1850wa. Just did the timing, and engine is correctly dialed in to 26 degrees at WOT, however, Im only getting a max of 4200 rpms and about 25kts. Thinking of dropping to a 13.25 x 17. Recommended max rpm is 4500-5500. What do you all think?
Bob_VT
Re: Prop size for 1997 Johnson 115 SPL
Yes, you are correct.
Welcome to iboats!
The Seaswirl is a heavy boat and you should do better with a 17" pitch
Is this a new to you boat? I would get it weighed and make sure you have dry flotation. Water "stored" in the hull will rob performance due to the weight.
Based on your number's you could almost go down to a 15" pitch but I would check the hull weight first........
egscharf
Thanks for the welcome Bob! I've owned the boat since april, but I run it at least 10 hours a week. Weight should be good, however, I usually carry about 130lbs. of water (via livewell), 100lbs of ice, and at least one passenger (200lbs), not to mention my toolbox and fishing equipment. The boat is rated at 2750 lbs. Hull is pretty solid, nothing to indicate a water storage issue. Could I really go wrong dropping to a 15? Sounds like the right course of action to me.
Welcome to iboats!
jestor68
5500 rpm(target) minus 4200 rpm(present) means you need to gain as much as 1300 rpm.
Putting a 17 will gain to about 4600 rpm. A 15 will gain to about 5000 rpm( good target; 115 hp at 5K rpm). A 13 would take you to about 5400 rpm( also a good target).
Right now, you're lugging that motor pretty badly. Not good.
egscharf
Thanks for the reply.
I've been able to find a 14 x 13, and a 13.75 x 15. Which do you think I'd be better off with?
Like I said, I'm currently running a 13.25 x 19. I troll quite a bit, but also frequently run at WOT.
jestor68
It appears that the 15 pitch would be the better choice for over all performance and fuel economy. As long as the motor can spin to about 5000 rpm, you'll be in good shape.
As an aside; the Mercury prop selector came up with a 15 pitch when I plugged in your info.
egscharf
Awesome, I'll pick the 15 up and let you guys know how it runs. Thanks so much for the help!
