Prop size
Michael Hagen
What prop size and pitch should I have on a 1990 yamaha 150hp outboard?
It is on a 21ft cuddy cabin.
steelespike
Re: Prop size
If you get us the info suggested we can probably help.
At the least we need your present prop size (usually on the barrel or under the prop nut)and your present max speed and rpm.your motors rated max rpm would help as well.
