Stan needs help!
- Joined
- Nov 19, 2009
- 2
I've got a 1981 Johnson 15 electric start that recently started acting like a slipping clutch after I hit something under water. I can be underway at WOT and suddenly the engine will rev away. If I back off the throttle it'll resume until some random point it'll start to slip again. My first thought was the prop hub is slipping but after just basic eyeballing the rubber hub appears intact. I noticed that the prop nut was basically loose and the front and rear washers show signs of spinning against the prop I figure that it might be normal considering that the prop is designed to slip in some situations. I was wondering if there is a proper setup tension for the prop nut or is the prop just worn out after 29 years.
