Prop slipping??
lncoop
Re: Prop slipping??
Yes you are correct.... Ventilation can lead to excessive slippage. Cavitation can lead to ventilation and/or slipping.
Ummm, you might want to read up on caviation.:confused:
Lakes84
Re: Prop slipping??
Ventilation and Cavitation
Ventilation occurs when surface air or exhaust gases are drawn into the propeller blades. The load on the propeller is reduced by the mixing of air or exhaust into the water steam causing over revving.
Anti-ventilation Plate: Large plate cast into gearcase housing directly above propeller. Helps reduce surface air from being pulled into blades.
Cavitation: The aeration (bubbling) and boiling effect of water caused by creation of a low pressure area. Generally caused by a solid shape (propeller blade) passing through the water, in such a position and speed, that a low pressure area is formed due to the inability to move through the water in nonresistant manner. An example is, a propeller blade that has a rough edge would not cut efficiently through the water, thus creating a low pressure area. If the pressure drops below the vapor pressure, a cavitation bubble will form in that region. These bubbles will collapse when they reach the higher pressure region of the blade. This causes a rapid change in pressure and can result in physical erosion. You may notice burns (erosion) at some area on the face of the blade.
Common rules of thumb:
Closely related. Similar to Impellars on a firetruck...same concept anyways. Degree in fire science (hydraulics) might help me a little.
Joe
