fbriggs
Thread starter- Joined
- Mar 30, 2017
- 26
Ok where to start, first info
Merc, 2001 2 stroke, 3 cyl eng. Model# 50ELPTO, Sn# OT182471.
Purchased motor heard it run off water on muffs, idle smooth good water flow out pee hole, shifted in and out of gear fine.
Took home installed on boat, took out to lake lowered motor opened throttle would barely move but engine reved up, right away thought prop hub bad. Pulled out looked at prop hub bushing looked a little suspecious so ordered a new hub. Back to lake same thing. Now no noise out of gear case like a shifting or gear problem so didn't know exactly what was happening. Before pulling gear case put into both Pulledfirward and Rev and grabbed prop could turn motor over with plugs in. So pulled lower unit to inspect all gears and spline shafts everything looks good to me, had some signs of rounded edge in dog and gears but nothing that looked bad enough to cause problem plus no noise like you would hear if gears weren't engaging correctly. Only thing I noticed was top spline on drive shaft had a twist to them like someone hit something pretty hard but that too would no cause problem I was having. Oh forgot to mention prop is a 11 3/4 x 10 alum 3 blade.
One more thing when engine would rev up and slip water would stop coming out and once at idle or you shut off and restart good stream of water. Water impeller like new key good and installed the correct rotation.
I have been a mechanic all my life and have worked on numerous motors of all kinds, overhauled motors, gas, diesel, LP, electric, 2 cycle and 4 stroke, and all makes of gearcases this really has me stumped. Any suggestions will really be appreciated. I evidently am missing something here.
Thanks
Thanks
