christopher425
Thread starter- Joined
- Jun 21, 2022
- 62
Hey guys, I change the impeller on my 1987 mercury mariner 45 HP two stroke 4cyl. and the shifting was off. It would go into forward and neutral but the prop would spin freely both ways in reverse. I took the lower head back off and looking at the cam shaft I manually shifted it from forward to neutral to reverse. My problem I'm having is when I put it in reverse it spins the same direction as forward. Meaning when I hear it click to lock the prop it will lock and catch when it goes in the counterclockwise direction. The same as when I move it into the forward position. It's like it has two forward gears, which I know makes no sense. The prop will not change directions like it should when going from forward to reverse. It's acting the same way in both gears. Does this sound like something in the gearbox that has gone afoul? Any help would be appreciated!
