Prop stuck on
badkins50
I took the nut and kep ring washer off and the prop will not come off. I wanted to ask how I should go about taking it off before I start at it again and screw something up. Thanks in advance.
oldjeep
Re: Prop stuck on
Take a rubber mallet and give it a few good whacks on the hub of the prop.
badkins50
Re: Prop stuck on
I gave that a try and no luck. I think I am up against something here. This thing will not budge at all.
oldjeep
Re: Prop stuck on
Tip the drive up and spray the splines with a bunch of PB blaster then let it soak.
If you don't care about the prop you could bash the heck out of it from behind.
Bob_VT
Re: Prop stuck on
Hit harder and use a wood block with a bigger hammer....... no grease on the shaft will act like glue!!
badkins50
Re: Prop stuck on
Ok I'll give it a try. I just didn't know if I'd be screwing up the shaft or anything else inside the lower unit by wacking on the propeller. Sure I'll be back in a little while. Thanks.
philsboat
Re: Prop stuck on
Use two prybars to put a little pressure on the prop.With the nut backed off so it is flush with the end of the shaft,whack the shaft end with a hammer with a block of hardwood to protect the shaft.A good sharp hit with the hammer should dislodge the prop.You need two people to do this properly.
Phil
