Prop suggestion for a 175 VMAX SHO
Capt. Lenny
Always in a search for the best all around performing prop for a Yamaha 175 VMAX SHO. I have tried an assortment of different props with mixed results. Just wondering what you're using and how you like it?
Ayuh,.... Welcome Aboard,..... What sorta hull ya got it on,..??
Tell us abit about the results ya got, along with pitches, 'n characteristics,..??
Capt. Lenny
The boat is a 2001 Ranger 200C fisherman Bay Boat with a T top that weighs about 3800 lbs. (because fishermen carry a lot of junk)19' 10" long 94" beam and it's the same hull as the Ranger 620 VS multi-species. The engine is a 2015 Yamaha 175 VMAX SHO. Here's some of the performance numbers that I've gathered.
Propeller performance - 2 people
Mercury mirage 15-1/2 X 17"
1000 rpm 5 mph 6.5 mpg trim 1
2000 rpm 9 mph 3.2 mpg trim 1
3000 rpm 23 mph 4.5 mpg trim 1
4000 rpm 32 mph 3.7 mpg trim 1
5000 rpm 40 mph 2.4 mpg trim 4
Yamaha Reliance 14-1/2” X 15”
11lb 14oz
2500 rpm 10 mph 2.9 mpg
3000 rpm 11 mph 2.4 mpg
3500 rpm 22 mph 4.4 mpg trim
Prop slip 17.68%
4000 rpm 28 mph 4.2 mpg trim 4
Prop slip 8.2%
4500 rpm 32 mph 3.7 mpg trim 4
5000 rpm 36 mph 2.2 mpg trim 4
5500 rpm 40 mph 2.3 mpg trim 6
6000 rpm 44 mph 2.2 mpg trim 10
Prop slip 3.96%
0-20 5.58 sec
Yamaha reliance 14-1/4 X 17
11lb 14oz
3000 rpm 13 mph 2.7 mpg trim 1
3500 rpm 25 mph 4.8 mpg trim 4
prop slip 17.46%
4000 rpm 30 mph 4.3 mpg trim 4
Prop slip 13.33%
4500 rpm 35 mph 3.9 mpg trim 6
5000 rpm 39 mph 3.0 mpg trim 6
5500 rpm 42 mph 2.4 mpg trim 6
5900 rpm 45 mph 2.3 mpg trim 10
Prop slip 11.86%
Mercury Vensura 14-1/2 X 17
3000 rpm 11 mph 2.0 mph trim 1
3500 rpm 25 mph 4.0 mpg trim 4
4000 rpm 30 mph 4.3 mpg trim 6
prop slip 13.33%
4500 rpm 33 mph 3.6 mpg trim 6
5000 rpm 37 mph 2.7 mpg trim 4
5500 rpm 41 mph 2.4 mpg trim 6
6000 rpm 44 mph 2.1 mpg trim 8
Prop slip 15.26%
Powertech PTZ4 14-1/4” X 16” 13 lb 4oz
2500 rpm 10 mph 2.7 mpg
3000 rpm 20 mph 4.2 mpg
3500 rpm 27 mph 4.5 mpg
Prop slip 5.2%
4000 rpm 31 mph 3.8 mpg 4 trim
4500 rpm 35 mph 3.3 mpg 4 trim
5000 rpm 38 mph 2.5 mpg 4 trim
5500 rpm 42 mph 2.2 mpg 7 trim
5700 rpm 43 mph 2.2 mpg 10 trim
0-20 mph in 8 seconds
Prop slip 11.68%
Powertech PTZ4 14 1/4 x 15 13 lb 4 oz
2500 rpm 9 mph 2.6 mpg
3000 rpm 14 mph 3.0 mpg
3500 rpm 25 mph 4.6 mpg 8 trim
Prop slip 6.45%
4000 rpm 30 mph 4.1 mph 9 trim
Prop slip 5.05%
4500 rpm 33 mph 3.3 mpg 6 trim
5000 fpm 38 mph 2.6 mpg 10 trim
5500 rpm 39 mph 2.3 mpg 8 trim
5700 rpm 41 mph 2.2 mpg 10 trim
Prop slip 5.80%
0-20 5.99 sec
Powertech PTZ3 14-1/4” x 15” pitch 11 lb 7 oz
2500 rpm 8 mph 4 trim
3000 rpm 10 mph 2.3 mpg 2 trim
3500 rpm 22 mph 4.0 mpg 6 trim
Prop slip 17.68%
4000 rpm 27 mph 4.4 mpg 6 trim
Prop Slip 11.86%
4500 rpm 32 mph 3.7 mpg 8 trim
5000 rpm 35 mph 3.3 mpg 8 trim
5500 rpm 37 mph 2.4 mpg 8 trim
6000 rpm 40 mph 2.0 mpg 9 trim
Clunk with engage in Fwd
Prop Slip 12.69%
0-20 mph 7.2 sec
Poor hole shot
Mercury High Five 13-1/2” X 17”
2500 rpm 10 mph 3 mpg trim 1
3000 rpm 12 mph 2.9 mpg trim 3
3500 rpm 23mph 4.6 mpg trim 4
Prop slip 24.06%
3800 rpm 25 mph 4.2 mpg trim 6
4000 rpm 25 mph 3.7 mpg trim 6
4500 rpm 29 mph 3.4 mpg trim 6
5000 rpm 32 mph 2.7 mpg trim 6
5500 rpm 37 mph 2.3 mpg trim 8
6000 rpm 40 mph 2.1 mpg trim 8-10
Prop slip 22.96%
Rough shifting w/Flo-Torq II hub
Great holeshot with 2 people
Mercury High Five 13-3/4” X 19”
2500 rpm 8 mph 2.1 mpg
3000 rpm 12 mph 2.3 mpg trim 6
3500 rpm 25 mph 4.3 mpg trim 6
Prop slip 26.18%
4000 rpm 30 mph 3.8 mpg trim 8
4500 rpm 34 mph 3.5 mpg trim 7
5000 rpm 38 mph 2.7 mpg trim 7
5500 rpm 41 mph 2.2 mpg trim 8
Prop slip 22.92%
Poor hole shot solo
Mercury Enertia 15” X 15” 13 lb 13 oz
3000 rpm 14 mph 3.1 mpg
3500 rpm 24 mph 4.7 mpg trim 4
Prop slip 10.19%
4000 rpm 29 mph 4.0 mpg trim 6
Prop slip 5.05%
4500 rpm 33 mph 3.8 mpg trim 6
5000 rpm 37 mph 3.0 mpg trim 8
5500 rpm 40 mph 2.4 mpg 8 trim
5800 rpm 42 mph 2.0 mpg 10 trim
Prop slip 5.16
0-20 5.10 sec
Good hole shot w/2people
Quiet shift W/Solas RBX hub
So, what am I looking for? Mainly a better holeshot when I have 3 or 4 people onboard without sacrificing much on top end. I lost the holeshot that I had with the old Yamaha 200 HPDI after it got struck by lightning. The short story is I got screwed by the marina I dealt with in Port Clinton Ohio when all this happened.
dingbat
The numbers on the Enertia are rather weird.
I’m running the same prop on a #5200 Grady Walkaround with a 225 HP.
Get similar results with the except for the “hump” in fuel consumption, which I’m guessing is right around where you come up on plane.
I get a weird chatter right before the transition. Assume I’m momentarily powering the prop but otherwise pretty happy with it.
May drop the 4 blade, Offshore Renegade I had on the boat previously to confirm my suspection
