I have a problem that maybe you all can help me with. Here is what I can tell you:
o 23ft. walkaround listed at 2700lbs dry and about 4000lbs w/engine,fuel,gear and me.
o Bottom is not painted, and there are no trim tabs
o Engine is a 1998 200hp Johnson with a 14.5 x 19p, 3 blade aluminum, 1:86 ratio
o WOT is 4300 rpms, yes 4300, speed is 37mph on GPS
o Engine runs very well, or at least sounds like it does
o Boat planes easily although I don't recall at what rpm or speed
o Tach is set to position "6"
I removed the prop recently and found the thrust washer cracked in two. Motor had not vibrated to any degree though. I purchased a 15 x 17p prop but that will only give me about 300-400 rpms. Any thoughts would help on how to get this engine in its optimal range of 5600-5800 rpms. Thanks to all.
