Re: prop tightness??????????/
Hi Spike,<br /><br />Ballpark - as tight as you can get it. Lubricate splines etc with grease first. File a mark across the end of the prop shaft first so that you can easily line up the split pin holes while tightening.<br /><br />I've been chicken with tightening mine before now, and found it loose after a days running, so now I just tighten it hard down.
