prop touching trim tab
paulspaddle
Changed prop from a 19p to 21p...now touches trim tab. Does tab have to be replaced or can tab be ground down abit?
If it can be ground down, how much clearance?
[/IMG]
arks
Re: prop touching trim tab
They make a flat replacement zinc with no fin. That might be the best solution.
Don S
Yes, you can grind it down. Give it about 1/2" of clearance.
Merc makes an offset trim tab anode for outboards that you can replace it with next time.
paulspaddle
Thanks Don, (posted same time as you)....will plug in the grinder.
JaseBosto
just grind some of it off...not the whole thing.
JaseBosto
I would use a beefy file before using a grinder.
Rocky_Road
Quicksilver also makes an offset tab for this situation:
apache61
I would go with the set back like Rocky showed
paulspaddle
Can someone explain what the tab does?
My understanding it offsets the torque of the prop. Therefore wouldn't not having one invite steering wheel pull?
My first i/o so all I know so far is 'theory' and no practical....yet.
Don S
It does. That is why it's on there. If you have power steering, it MAY not make any difference. If you don't have power steering you absolutely need it.
ziggy
yep, grind it off. the 4'' angle grinder Don S talks about makes short work of it.
this is how it can turn out..
this grind it off method also appears in the s/m as the proper way to make it work. i think s/m #6. but not sure. am sure i've read it in the s/m though...
grind away.... :D
paulspaddle
I'm well versed in grinding/trimming/whatevering....to make something fit...thanks for the pic Ziggy.
littlebookworm
Grinding it down a little is no big deal; very common, actually. Mercruiser and after-market suppliers list a number of different fins for Mercruiser drives. Very often the "specified" one is hit by the prop, especially if the prop's been replaced. That's why you always turn the prop by hand, with the engine off, whenever you replace a zinc "fin" or a prop. Grind away! Hy
