Prop Vs. Wot. Vs. Redline
scott449
I have a bayliner 205 with a 5.0L Merc. The prop I have on there now is a 19P
At WOT the RPM will go to 4800. The WOT range for this engine is 4400-4800
I would like to put a 17P or 15P prop on when I am using the boat for wakeboatding. My concern is that if I am not carful I will take the boat past 4800 RPM with this prop.
Will running the 5.0L above the 4800 rating trash the engine?
Is there a REDLINE for this engine?
Re: Prop Vs. Wot. Vs. Redline
Ayuh,... 4800rpms....
You just have to be Careful when using the smaller prop...
steelespike
Your not supposed to go beyond 4,800. An occasional venture beyond isn't going to damage it. Extended operation will cause premature failure.
