Prop Walk, need a possible solution.
Laguna 20
I have a 1989 SeaRay Laguna 20' Center console, couple of years back I purchased a New 150 HP Mercury SeaPro outboard motor. Prop works great moving forward and gets me to the full rated RPM's at 5200.
Problem is when backing up it doesn't seem to respond correctly unless I'm going very slow, any throttle at all and it just goes straight it and doesn't respond. Someone told me it's "Prop Walk"
The original motor was a 200 HP Mercury 2-Stroke backing up at any speed provided great control, this prop was transferred to the new motor, per the dealer the prop would work great.
Where to I start to address this issues?
Jerry
Does the new and old motor have the same length shaft?
Is the Cav plate and prop below the keel?
Chris1956
I thought prop walk was when the boat moves to the side of the "hand" of the prop. i.e. in forward with a right hang prop, the stern will move to the right a bit.
Does the motor (swivel) steer the same amount in both directions? Sometimes they turn a lot more in one direction, due to improper dealer or owner set-up.
dingbat
My neighbor had the same issue when the marina mounted a new 20" shaft outboard on his 25" transom boat.
Other than that, a very common issue on a bracketed boat since the thrust hits the transom.
garbageguy
consider the prop's angle to the water line with the old and new motors when backing
Texasmark
How did that perform in F gear. Other than slow to slow planing speeds, I can't imagine that working. Once you are up to speed, half the blade area is in the air.
dingbat
Maxed the boat out going from 115HP to 150HP on a 17' boat.
A little squirrelly, but not bad at all. The issue he had, and why he asked me to test drive it for him was that it took Popeye to steer the boat to port .
He ended up getting a lawyer to make them put the proper 25" shaft outboard on the boat.
