Propeller Locks
crobar
I'm looking into a lock for my propeller and am leaning toward the McGard prop lock. However a service tech at one of the local boat dealers recommends not using one of these prop locks because if they seize up the unlocking device won't work and the locking device has to be cut off with a torch. Has anyone heard of this type of problem?
Frank Acampora
Re: Propeller Locks
That's why you remove them frequently and check for proper operation.
crobar
Re: Propeller Locks
Apparently this question fell into the "stupid question" category. Are these locks commonly used and have a favorable reputation or are they avoided by those in the know?
Rocky_Road
Re: Propeller Locks
Very rare to see one where I boat...they almost make it impossible to change your prop, if needed, while on the water.
Not to mention, that I believe that the McGard doesn't have the ability to use the locking tab pieces....
crobar
Re: Propeller Locks
That's a good point about trying to change the prop while on the water. In reality the lock would only be needed at times when we are going a long distance and have to stay the night in a hotel. It should be easy enough to just use it when in transit and then change it out when we are home or at the destination.
Thanks for the help
soaringhiggy
Re: Propeller Locks
Or just remove the good prop and install a guard on the shaft of an old junk prop.
crobar
Re: Propeller Locks
That's an interesting idea. Mounting a junker prop on it with the guard should serve to reduce or eliminate the temptation to steal it in the first place.
