Propeller Shaft Seals
Modelt4d
I have a 1980, 20 hp, Mercury outboard, and I have to change the propeller shaft seals. Can someone give me an ideal as to the procedure for doing this job. Thanks
andrewkafp
Re: Propeller Shaft Seals
Are you sure you have bad seals? Sometimes unburnt fuel/oil will drip out of the prop.<br />Do you have water in there ?<br />If they are definately bad, the procedure involves using some special tools and is best done by a pro.<br />A workshop manual will take you through the steps.
