1970Thunderbird
Thread starter- Joined
- Dec 24, 2009
- 111
Hey all (again),
I had a sneaking suspicion that part of my lack of power under load might have been something other than the prop or fuel, so I ran a compression check. Here are the results.
cylinder 1: 95psi
2: 95psi
3: 85psi
4: 65psi
I take it have either a bad set of rings or a bad head gasket. Perhaps both.
Anything I should know before I tear into it? I'm planning on redoing the rings for all the cylinders since I'll have the motor that torn apart anyway. Maybe get some new pistons.
What size rings do I need for stock pistons? If I get new pistons, which ones do you recommend?
And what compression should I be showing, anyway? I've heard 120psi.
Thanks for everything.
cylinder 1: 95psi
2: 95psi
3: 85psi
4: 65psi
