diaric
- Joined
- Jul 8, 2006
- 532
I just installed a CMC tilt trim on my old runabout with my 1966 merc 500. The motor sits back an extra 6 inchs now and by the instructions the motor should be mounted from 1 to 3 inchs higher than stock. I have it about 2 inchs higher. The boat doesn't get up and go as well now, it takes longer to get up on plane and when you give it throttle it doesn't rev up immeidatly like there is more water resistance against the prop. Top speed hasn't changed, still does 30 mph with 11 pitch prop. Is the motor still alittle low and how do u figure the best height?
