froggy1150
Ensign
Thread starter- Joined
- Nov 3, 2017
- 914
i felt froggy so i am going to leap on this one! thanks kcassells. this is strange doing this on a computer, i am a phone guy.
i have read "yacht survey fuel tanks install" ~ 4 times. i have read alot of posts here and on other less worthy forums.etch with alodine, paint, dont paint, open air, rhinoline....... it was last year i did most of my research and had settled on this if i remember right. acid etch, coat with gluvit to seal and refoam in cuz thats how it was originally. i always read as much as possible and have not installed tank yet.i read kcassells debate a few weeks ago ( we are listening, thanks) and started second guessing my plan. i am going to follow the open air procedure. i will have to do some rework to make it structurally sound because that area was foam but safety is foremost! knowing whats safe and doing less is negligent. i have read that coating with epoxy is good, and have also read that if you coat it can crack and hold moisture. i have read to just etch with alodine or zinc cromate. also have read that if its open air it will produce its own protective coating.about the only thing thats consistent is to support with neoprene. i went thru the " how to sticky" and i didnt see this covered either and because there is so many opinions on whats right and whats acceptable. i didnt include this on my post but kept it seperate and maybe it can go into the how to section when its got some good info in it. sooooooo how to prep? how to coat?support? hold in position with and with out mounts? etc....... let the debate begin!
