almost 5100 with a 19P prop on her.
Could anyone point me in the direction of the proper documentation and/or steps to perform a full leakdown test on a 3.0LX?
Ayuh,... So put a 21" on her....She's gainin' Horsepower,....
Maybe it's foamin' cause yer Revin' the crap out of it....
Get your cylinder so both valves are completely closed,and stay closed, whatever it takes to accomplish this.
Thanks all for the tips. I've read up on automotive websites about how to do it, but am wondering if there are any special tips for doing it with our engines/manifold/cooling setup..
This would be just TDC for each cylinder, correct?
It's a 4 stroke engine, crankshaft turns 2 times for the cams one time. You have to be on TDC of the cylinder you want to test, while on the compression stroke, NOT the exhaust/intake stroke.
This may help http://www.animatedengines.com/otto.html
A 3.0 is a six banger (right) so you'll have 3 marks 120 degrees of rotation apart.
