Proper leakdown test procedures
mark1905
Could anyone point me in the direction of the proper documentation and/or steps to perform a full leakdown test on a 3.0LX?
Re: Proper leakdown test procedures
Ayuh,.... Are ya chasin' an Issue, or just wantin' to know,..??
I just hook my shop air to my compression tester, 'n put the air to it, after ya block it from turnin' the motor over(at Tdc of course)...
If ya hear air leakin', is it to the intake, exhaust, or base...
That's where ya wanta look Deeper...
mark1905
I'm getting a good amount of blow by/air pressure and foamy oil out of the valve cover vent.. and hoping it's not my rings going bad. Engine is also starting to be able to rev way too high. She used to max at 4800 and now I can get her up to almost 5100 with a 19P prop on her..
Ayuh,... So put a 21" on her....;) She's gainin' Horsepower,.... :D
Maybe it's foamin' cause yer Revin' the crap out of it....
tpenfield
You'll need a leak tester and a compressor
You can google procedures, and there is probably one that will accompany the tester. Essentially, you put the cylinders at TDC one at a time and then connect the tester to each cylinder. The difference in the gauges is used to calculate the leak. 10% leak is good, 20-30% is fair, and 30+% is not so good.
scoflaw
Ensign
Leakdown tester has 2 guages. Set the shop air guage at 100 psi. Get your cylinder so both valves are completely closed,and stay closed, whatever it takes to accomplish this. Screw air hose into spark plug hole. Open the air valve on the tool, and read the second guage. Keeping the shop air guage at a 100 psi, you can now read the leakdown as a percentage.
mark1905
Lol.. I don't make it a habit.. but it occurred to me like a ton of bricks yesterday that maybe she's able to rev higher now because there isn't as much resistance in the form of compression..
Getting a good amount of air just at idle. I can't keep my finger plugging it.. it blows it right off..
..and enough oil blowby that it's puddling against the valve cover and running down the engine, all over the starter motor and into the bilge..
Thanks all for the tips. I've read up on automotive websites about how to do it, but am wondering if there are any special tips for doing it with our engines/manifold/cooling setup..
This would be just TDC for each cylinder, correct?
tpenfield
Nothing special for the marine engines versus the automotive on the leak testing. Valves are closed at TDC (hopefully), so that is where you want to be. I use the timing mark on the Harmonic balancer as a reference point and then make the additional marks (with chaulk or something) for the other cylinders. A 3.0 is a six banger (right) so you'll have 3 marks 120 degrees of rotation apart. I have a V-8, so I get 4 marks 90 degrees apart. Then it is a matter of turning the engine to the next mark (breaker bar on the balancer bolt) and testing the cylinders according to the firing sequence.
Let us know your numbers when you're done. :)
Don S
It's a 4 stroke engine, crankshaft turns 2 times for the cams one time. You have to be on TDC of the cylinder you want to test, while on the compression stroke, NOT the exhaust/intake stroke.
This may help http://www.animatedengines.com/otto.html
mark1905
Lol.. I knew what I was trying to say in my head.. just it didn't come out right. I gotcha.
No.. inline 4..
tpenfield
4 cylinder . . . then the marks are even easier; 2 marks at 180 degrees. so, like Don says you'll turn the crankshaft 2 revolutions to get all 4 cylinders.
