I recently purchased a Solas 4 Blade Aluminum 14.25x19 from Iboats for my 1986 alpha one. I tried installing the new prop and it is too long it will not pass the (trim tab) anode If I take the thrust washer off I have no problems. Does the washer need to be there with the new prop or should I send the prop back? The other prop is a 3 Blade 14.25x19. My current thrust washer #is 77987
