Proper RPM for a Volvo Penta 501(Gm 305)
JaseBosto
I switched from a duo prop setup to a single. Got my reasons. Anyways, I am not sure what the rpm range is for this setup of mine.
1990 Larson Hamton Sport cruiser
22'
8.5' beam
Volvo penta 305gm V8 with a frankenstein outdrive(DP-A upper/intermediate 280 lower).
aerobat
Master Chief Petty Officer
Re: Proper RPM for a Volvo Penta 501(Gm 305)
depending of what exactly 305gm engine you have you are looking either for 4200-4600 or 4400-4800rpm .
cheers
Don S
42-4600 rpm for both the 501A and B engines.
jestor68
According to the Volvo web site:
The engine data base says max rpm is 4600.
The down loadable AQ brochure(2/2/2007) says 4400-4800.
Since there's only a 200 rpm difference between the two, it looks like it doesn't really matter which you use.
Don S
Yes, the max rpm for that engine is indeed 4600 as stated on their site, the 4200 to 4600 came from the service manual and repeated in the owners manual.
I would assume those 3 items would probably override the reprinted sales brochure that says 44-48. But that is just a guess.
