Proper Trim/Tilt motor operation????
brokemerc
Took 4 gallons of oil but I finally have all or at least most of the water out of my tirm/tilt system (milk is gone). When the drive is in the full down positon I drive it up with the trim switch and it will drive up until full up and then will automatically shut itself off. But..... when I drive it down when the drive gets in the full down position the motor will slow and act like it's under a load but will continue to run,,, is this normal or should it shut itself off when full down??? In trailer up position it does the same thing, it'll bog down but continue to run.. Normal or AbyNormal...
tommays
Re: Proper Trim/Tilt motor operation????
The only time it shuts OFF auto is when you are useing the trim UP and the trim limit switch is working :)
Trim down is NOT auto and the Trailer position is NOT auto
Tommays
brokemerc
WOOHOO<<<<< something finally works correctly..... I'm on a roll.... Thanks,, now let me write a post about this firing order..
