proper way to do a copression test
zanman
can any one tell me the correct way to do a compression test on a twostroke outboard motor,hot cold, squirt of oil or not.<br /><br />thanks Z
Kenny Bush
Re: proper way to do a copression test
Run motor until it reaches operating temperature. Then disconnect all sparkplug wires. Open throttle to wide open. Engage kill switch if you have one. Unscrew #1 plug. Insert compression guage. Turn motor over for about 3 seconds. Record results. Proceed to number 2 cylinder......3..4..until all cylinders are done. There should no variance of more than 15% from the lowest reading to the highest.
wilde1j
Suggestion: remove ALL spark plugs before beginning!
Fouled Plug
Ensign
If you get a low reading, a squirt of oil will indicate bad rings if it bumps up compression.
Kenny Bush
Leave the plugs in....... only remove plug for compression guage. If you leave out all plugs, it will trick test(must have each chamber isolated).
