- Joined
- Jul 23, 2011
- 53,103
first, take a sharpie and draw a line across the prop hup and nut. if the line moves its your prop hup
second, pull the drive, drop the lower and look at the vertical drive shaft. may as well do an impeller. while at it pull the top cover and look at the gears
third, use a flashlight and look at the coupler. you will either see missing splines or a ring around where the spline sleeve used to be bonded to the rubber.
