1080tommy1
Thread starter- Joined
- Feb 13, 2012
- 55
Ok , I have a 2002 Alumaweld Xpress 1650 DB. I put a Yamaha C40 TLRX on her and need some help with the right prop. The current prop is a 12 1/4X9-G which I think is not the best prop because of the performance and rpms. The boat has an incredible hole shot but than when WOT the boat seems to be running at too high rpms and falling on it's face. I also noticed the fuel efficiency to be really bad. I do not know the exact rpms and just installed a Tiny Tach and will take the boat out tomrrow to find out actual WOT rpms are but if I am at a 9 pitch, how many degrees do I add to lower the rpms. WOT for this motor is 4500-5500.
I guess what I am actually asking is the relationship between adding pitch and the resulting rpms. I read that adding 1 degree of pitch will decrease rpms roughly 200 rpms. Is this correct? Also, how does diameter affect rpms. I noticed that this prop is the largest diameter with the flatest pitch listed for my motor and all of the other props listed are smaller diameter.
I am new to having a boat or an outboard motor so I hope this is the right format for the question and am sorry in advance if the question is not clear. Just don't want to over run the motor and do some damage. I will report what actual rpms are tomorrow if I can get out after work. Thanks in advance for any advice anybody could give a noob with some confusion on how to get the right prop. I am probably making this way more complicated than it has to be.
