Props for Sunbird SWL 203
Andrik
I have changed motor from Evinrude Ocean Pro 175 to 150 on my Sunbird. The prop on the 175 was a Raker 14 1/2 x 20, the prop on the 150 is an ordinary 14 1/2 x 21+. Which one will be best for my Sunbird SWL 203? I have noe experience on this.
steelespike
Do a lightly loaded wot test run with each prop. get us the wot rpm and gps speed for each.
Andrik
No Title
Thanks. But can anyone tell me how to loosen the Raker prop? Do I need a special tool? It seems not to be mounted mounted with a splitpin. Plese see attached picture.
Ayuh,.... That's a prop lock nut, much like those on fancy car wheels,....
Ya need the "Key" piece to unscrew it,....
Andrik
Ok, thanks. Do you know where I can get it?
Ayuh,.... If yer lucky it's stuffed into a storage spot somewhere in the boat,....
