Pros and cons of bow or stern mount trolling motors
mommicked
I seem to have to constantly adjust my bow mount in 10+ winds while fishing.Im thinking of putting one on the stern and fishing w the wind to my back instead of bow in the wind, maybe in reverse to slow my drift.Any thoughts on this?
ezmobee
Re: Pros and cons of bow or stern mount trolling motors
Uh oh, my response isn't going to be too helpful.....I came here to post that I had to constantly adjust my stern-mount and am looking forward to installing my bow mount!
I guess we've both just killed each other's dreams :redface:
Bass Buster One
Mommicked, typically I can't stand to go out when it's really windy, but I don't let it run me off the lake either, should I already be out and the winds come in. I've had a number of years experience with a transom mounted trolling motor, as compared to bow mounted, which I've only just begun (last fall) using. I have to tell ya, I constantly had a horrible time trying to orient the boat from the rear; wind would take it where ever it wished, even a slight breeze. When I started using a trolling motor on the bow (different boat, I'll grant you), I learned right away that it's much easier to control the boat by pulling it rather than pushing it. Now this is just my opinion, and I know everyone has one, but I'd bet you'll agree, you see at least 25 bow mounted trolling motors to every transom mounted one.
ezmobee
I think a bow mounted troller would be much less effected by an oversteer (overcorrection) then a stern mount.
mommicked
Im taking my elderly dad fishing alot and Id like him to be up front.We fish for bass mostly and fish the bank alot.My 10 yr old motorguide is a pain w the footcontrol and cable always in the way, dad wont run it.My bow also rocks pretty good w wakes on our crowded lakes making it tricky to stand and fish as I prefer.Dad sits in a swivel seat.I wouldnt get rocked as bad standing in the back of my stern heavy 18 Jonboat and Dad would get to cast first at structure as we drift/troll the bank.Im thinking of a hand control stern mount w a long shaft to make it easy to reach.I think my motor isnt as powerful as it was when new, maybe part of my problem. Im planing on getting a 70 or 80 lb instead of the old 46.Im think Im gonna test Drive a friends clamp on unit and see how I like it.Thank you all, your opinions are greatly appreciated.
greenbush future
It's push vs pull, and if you add wind the pulling (bow) will win every time. We fish the Detroit river vertical jigging for walleye. Trying to drag a boat backwards will wear your battery down and you wont acheive good results. Bow is the best method, that's why they cost more and you see them everywhere. Hope this helps.
coopcafemgr
You might try one with a remote control you can step on or hold in your hand. they work great to keep the deck clean.
JB
I can see a transom mounted troller for a small boat with one fisherman who wants to stay in the stern seat while trolling. They are also a lot less bux than a bow mount.
For any other application I want a bow mount PULLING rather than PUSHING.
Any situation that requires constant corrections of a bow mounted troller would be uncontrollable with a transom mount.
j.4knee
You could also look into one mounted on your cavitation plate, then just steer normally.
jigngrub
I have one of these and love it! I have the Motorguide Wireless 55 lb. with the key fob controller.
I can steer and control the speed from anywhere in the boat.
It really sucks to be a slave to a foot control!... the only thing worse is having a transom mount TM, those things don't steer a boat worth a crap.
Go for the wireless bow mount, you'll be glad you did.
mommicked
Ive seen enough to forget this plan.I tried to mount a stern mt. and the clamp knobs hit my bilge hatch in the back before it was down on the transom.Id have to rig a bracket to use a stern mount, and I thought about shallows and logs/rocks etc.and dad yelling "Turn hard right/left!" when trying to follow twisty narrow creek chanels lined w primrose and milfoil that I couldnt see from the stern.I also discovered some balls missing in both of the bearings on the TM shafts.I replaced them for free w a handfull I got from a bicycle shop and greased them and now it turns easily and quietly(I thought It was just wore out before I took it apart).Its still underpowered and Im looking for a bow mount hand control now.Thanks for the replies everyone.
bassman284
Well, it's pretty much all been said but my own $.02, I've had the chance to try both on roughly the same boat and bow mount wins by a landslide. WAY more controllable, given that big wind makes anything difficult to control.
mommicked
Thanks again for the comments.I also believe you cannot have too much power in a TM.Unless you hit high speed while standing with a bow mount motor turned 90 degrees to the bow and it flings you overboard:eek:Im also getting a variable speed this time.
Paul Pro
I recently pefected the handling on my 10" jonboat by adding a homemade rudder,plexiglass,and a wood handle,which I wedged comming up through one of the handles in the stern.I did make one screw hole at top to keep it from sliding left to right. I had to cut the wood handle a little more since I had wraped the handles in a rag,then ductape. Just for added comfort.The rudder works awesome , In the past I've used another trolling motor dragging from stern to help, but this worked out the best ,I steer from bow,and I have no problems. I can fish in straight line finally,I can easily fish the banks now,usually with someone in the boat ,I wont use the rudder,but I'm gonna try the rudder in the bay with fishing partner,and see how it goes .s Rudder is around say 9inches long and runs 4 inch deeper than the "floor" of my boat,I pre drilled 4 holes and used screws,also used "goop" glue.you could always glue to pieces of plexi together if all you got is thin stuff.Plus the rudder has like zero drag.I used a circular saw,drill,and a hacksaw,for plexiglass.The rudder makes sterring less responsive,without it I could kick out my back end,with a quick 180.I use a motorguide 54,I turned the head 180 on this motor for bow use.I removed my center seat, so I have lots of space ,I stay at the bow all the time now,I let my buddy sit at the stern.keeps me closer to the fish:facepalm:I can't wait to see how we move with the 2 of us .My 54,and his great white 55 sw,I'm gonna put his at the stern.and take 2 batteries.You know you can hook up 2 motors to 1 battery by the way.
I like the fact that the boat is better ballanced depending on your boat?I use an extension handle for long runs, and sit a little more towards the middle.Handling is much better with the bowmount,much more control of the bow.Onlything is that the backend gets really loose,its fun if you like "driffting".I made a rudder,which helps keep me on that straight and narrow
a picture says a one thousand words...this is a still shot from a vid..this was main reason for posting,plus my middle seat removall,and bowmount.I hope this rudder idea helps..this keeps the boat in a straight line.holds the backend nice..
maybe depends on boat.My 10"jon boat has bowmount.back end swings out wost now,before I had the keel of my motor at least to keep back end from drifting.I had to correct this with a rudder
dual rudders, I use one and works like a charm,keeps the boat straight even with some wind.Or get a digi for the stern,have it locked at a 90,then you just have to turn it on or off at a preset speed,we fish this way with a bow mount when wind is in our favor,"behind and from the left".Sorry I thought I had a side shot of my homemade rudder.I rec,heavier duty plexi,or wood,fiberglass.this was my ticket for salvation,I am new to a bowmount, quickly realized its cons.there is allways a solution.this rudder idea was my main reason I joined.I hoped this rudder workes out for larger jon boats I don't see why not good luck,my buddy attached mine from the boat last trip took him almost 2min first try.I usually put it on from shore.I made the holes bigger in the wood so I can insert screws by hand,or use screwdriver.I used only one screw before, . with one screw you have to screw it on tight,to keep rudder in possition.now I use 2 but barely catch each by hand.
